Virtual Routing and Forwarding (VRF)
Oracle SD-WAN Edge 5.0 introduces Virtual Routing and Forwarding (VRF) which gives network administrators tools to segment their networks to separate different types of network traffic, create and manage distinct routing domains, support and manage multiple tenants at Client Sites, and segment network traffic to support multiple networks. In Oracle SD-WAN Aware 2.0 Network Maps you can hover over a Site to view site elements including the Routing Domain.
Only the first eight Routing Domains will be displayed for a site. If more than eight Routing Domains are configured at a site, to see the full list click More.
Figure 1: Network Map Elements Including Routing Domains
From the Monitor, and then Network Maps screen you can click on the Routing Domain drop-down menu to filter the Sites displayed by Routing Domain.
Figure 2: Network App Elements Filtered by Routing Domain
From the Monitor, and then Graphs screen you can click on the Routing Domain drop-down menu to filter the objects and properties displayed by Routing Domain. Sites not in the selected Routing Domain will be hidden in the tree.
Figure 3: Graph Objects Filtered by Routing Domain
From the Monitor, and then Reports screen you can click on the Routing Domain drop-down menu to filter Reports displayed by Routing Domain.
Figure 4: Reports Filtered by Routing Domain
