BGP Verification and Troubleshooting
After the replacement, login to the web UI of the APNA and navigate to Monitor > Statistics to verify that the change is successful.
This will bring up the Paths (Summary) statistics page. Verify that Path State and Conduit State report GOOD for each WAN Link as shown in the image below.
Next, use the dropdown menu to select Routes to verify that the expected routes are properly being learned via BGP. In the example below, notice the 10.3.1.0/24 route shows Type as Dynamic and Protocol as BGP.
The route must also be considered reachable for it to be used.
