Introduction to Oracle SD-WAN Aware 8.2.0.0.0
The Oracle SD-WAN Aware
Release Notes
provides the following information about the 8.2.0.0.0 release:
- Specifications of supported platforms, virtual machine resources, and hardware requirements
- Overview of new features and enhancements
- Summaries of known issues and limitations
Coproduct Support
Oracle SD-WAN Aware 8.2.0.0.0 is supported in combination with the
following version of Oracle SD-WAN Edge:
- 8.2.0.0.0
Supported Web Browsers
The Web Console is supported in the latest versions of the following web
browsers:
- Microsoft IE9 - IE11
- Mozilla Firefox
- Google Chrome
Supported browsers must have cookies enabled, as well as JavaScript installed and enabled.
Installing and Upgrading
First-Time Installation
Install Aware VM Image. See Talari Aware Installation and Upgrade Guide.
Upgrade from previous versions
If upgrading from 8.1 GA or earlier:
- Install full Aware VM Image and perform non-disruptive database migration from the old Aware VM to the new Aware VM. See the Oracle SD-WAN Aware 8.2 Installation Guide.
If upgrading from 2.1 GA or earlier:
- Aware version 2.1 MIGRATION needs to be installed on the existing Aware VM prior to upgrading to any version beyond 2.1 MIGRATION. Once you have completed the upgrade to 2.1 MIGRATION once, you may safely upgrade to all later versions of software without the need to reinstall 2.1 MIGRATION a second time.
If upgrading from Aware 1.0 GA H2 or earlier:
- Install full Aware VM Image and perform non-disruptive database migration from the old Aware VM to the new Aware VM. See Talari Aware Installation and Upgrade Guide.
If upgrading from Aware 1.0 GA P1 or later:
- Install Aware Software on existing Aware VM. See Talari Aware Installation and Upgrade Guide.
Upgrade Considerations
- Ensure your SSH client is upgraded to a current, stable version before connecting to Oracle SD-WAN.
