| Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide Release 1.0 F16985-01 |
![]() Previous |
![]() Next |
User may have to update nrf client service related configmap. Following are few scenarios:
The nrf client configmap establish connection between NRF and BSF, in order to register BSF to NRF services and hence it is mandatory to update configmap to use correct nrf service URL and apply some extra settings.
If no NRF deployed under current kubernetes cluster, then ignore the following settings under this section as there is no need for BSF to register itself to NRF service. The only way to invoke BSF services is to get API service URL manually then send request to it directly.Before updating nrf client service, perform the following:
To update nrf client service:
kubectl get configmap -n <
BSF-Namespace>
kubectl edit configmap
<BSF-NAME>-application-config -n <BSF-Namespace>
At least one of the address parameters such as fqdn, ipv4address or ipv6adress should be populated in the NF Profile under configmap definition. NF Profile here indicates the entrance of current deployed BSF which means it is the API Gateway service URL(FQDN), API Gateway service IP V4 address or IP V6 address.
appProfiles=[{"nfInstanceId":
"fe7d882b-0541-4c7d-ab84-c6d70b1b0123","nfType": "PCF","nfStatus":
"REGISTERED","plmn": null,"nsiList": null, "fqdn": null,"interPlmnFqdn": null,
"ipv4Addresses": null,"ipv6Addresses": null.......
It is recommended to update the fqdn value while keeping ipv4Addresses and ipv6Addresses as it is.
For example, consider ocbsf-api-gateway.bsf1-1:80 for fqdn value. Following result displays:
"ocbsf-api-gateway.bsf1-1:80","interPlmnFqdn": null, "ipv4Addresses":
Refer to Get BSF Profile to get actual fqdn value.
"ipEndPoints":[{"ipv4Address":"ocpm-staging-bsf-2-api-gateway.ocpm-staging-bsf-2.svc","ipv6Address":null,"transport":"TCP","port":5903}]
to "ipEndPoints": null
