| Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide Release 1.0 F16985-01 |
![]() Previous |
![]() Next |
Following are the pre-requisites before installing Binding Support Function.
BSF Software
BSF software includes:
| Software | Version |
| Kubernetes | v1.12.5 |
| HELM | v2.11.0 |
| MySQL | 5.7 or later |
Additional software that needs to be deployed as per the requirement of the services:
| Software | Chart Version | Notes |
| elasticsearch | 1.21.1 | Needed for Logging Area |
| elastic-curator | 1.2.1 | Needed for Logging Area |
| elastic-exporter | 1.1.2 | Needed for Logging Area |
| logs | 2.0.7 | Needed for Logging Area |
| kibana | 1.5.2 | Needed for Logging Area |
| grafana | 2.2.0 | Needed for Metrics Area |
| prometheus | 8.8.0 | Needed for Metrics Area |
| prometheus-node-exporter | 1.3.0 | Needed for Metrics Area |
| metallb | 0.8.4 | Needed for External IP |
| metrics-server | 2.4.0 | Needed for Metric Server |
| tracer | 0.8.3 | Needed for Tracing Area |
In case any of the above services are needed and the respective software is not installed in CNE. Install the software before proceeding with BSF installation.Note:
If you are using NRF, install it before proceeding with the BSF installation.Network Access
The Kubernetes cluster hosts must have network access to:
Local docker image repository where the Oracle Communications Binding Support Function images are available
Laptop/Desktop Client Software
Following are the requirements for the laptop/desktop where the deployment commands shall be executed:
Helm client installed with the push plugin. The environment should be configured so that the helm install command deploys the software in the Kubernetes cluster.
Browser Support
It is recommend to use Firefox browser to access Kubernetes dashboard. The Configuration Management GUI page is accessed from different browsers.
Server or Space Requirements
For server and space requirements, refer to Oracle Communications Cloud Native Environment Installation Guide.
