This table below lists terms used in this document.
Table 1-1 Key Terms
| Term | Definition |
| Host | A computer running an instance of an operating system with an IP address. Hosts can be virtual or physical. The HP DL380 Gen10 Rack Mount Servers and BL460c Gen10 Blades are physical hosts. KVM based virtual machines are virtual hosts. Hosts are also referred to as nodes, machines, or computers. |
| Database Host | The Database (DB) Host is a physical machine that hosts guest virtual machines which in turn provide OCCNE's MySQL service and Database Management System (DBMS). The Database Hosts are comprised of two Rack Mount Servers (RMSs) below the Top of Rack (TOR) switches. For some customers, these will be HP Gen10 servers. |
| Management Host | The Management Host is a physical machine in the frame that has a special configuration to support hardware installation and configuration of other components within a frame. For CNE, there is one machine with dedicated connectivity to out of band (OOB) interfaces on the Top of Rack switches. The OOB interfaces provide connectivity needed to initialize the ToR switches. In OCCNE 1.0, the Management Host role and Database Host roles are assigned to the same physical machine. When referring to a machine as a "Management Host", the context is with respect to its OOB connections which are unique to the Management Host hardware. |
| Bastion Host | The Bastion Host provides general orchestration support for the site. The Bastion Host runs as a virtual machine on a Database Host. Sometimes referred to as the Management VM. During the install process, the Bastion Host is used to host the automation environment and execute install automation. The install automation provisions and configures all other hosts, nodes, and switches within the frame. After the install process is completed, the Bastion Host continues to serve as the customer gateway to cluster operations and control. |
| Installer Bootstrap Host | As an early step in the site installation process, one of the hosts (which is eventually re-provisioned as a Database Server) is minimally provisioned to act as an Installer Bootstrap Host. The Installer Bootstrap Host has a very short lifetime as its job is to provision the first Database Server. Later in the install process, the server being used to host the Bootstrap server is re-provisioned as another Database Server. The Installer Bootstrap Host is also referred to simply as the Bootstrap Host. |
| Node | A logical computing node in the system. A node is usually a networking endpoint. May or may not be virtualized or containerized. Database nodes refer to hosts dedicated primarily to running Database services. Kubernetes nodes refer to hosts dedicated primarily to running Kubernetes. |
| Master Node | Some nodes in the system (three RMSs in the middle of the equipment rack) are dedicated to providing Container management. These nodes are responsible for managing all of the containerized services (which run on the worker nodes.) |
| Worker Node | Some nodes in the system (the blade servers at the bottom of the equipment rack) are dedicated to hosting Containerized software and providing the 5G application services. |
| Container | An encapsulated software service. All 5G applications and OAM functions are delivered as containerized software. The purpose of the OCCNE is to host containerized software providing 5G Network Functions and services. |
| Cluster | A collection of hosts and nodes dedicated to providing either Database or Containerized services and applications. The Database service is comprised of the collection of Database nodes and is managed by MySQL. The Container cluster is comprised of the collection of Master and Worker Nodes and is managed by Kubernetes. |
