Go to primary content
Oracle® Communications OC-CNE Installation Guide
Release 1.0
F16979-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Inventory File Template
The host.ini file contains the inventory used by the various OCCNE deployment containers that will instantiate the OCCNE cluster.
Template example
The inventory is composed of multiple groups (indicated by bracketed strings):
  • local: OCCNE ansible use. Do not modify.
  • occne: list of servers in the OCCNE cluster that will be installed by the os_install container.
  • k8s-cluster: list of servers in the kubernetes cluster.
  • kube-master: list of servers that will be provisioned as kubernetes master nodes by the k8s_install container.
  • kube-node: list of servers that will be provisioned as kubernetes worker nodes by the k8s_install container.
  • etcd: list of servers that will be provisioned as part of kubernetes etcd cluster by the k8s_install container.
  • data_store: list of servers that will be host the VMs of the MySQL database cluster, os_install container will install kvm on them.
  • occne:vars: list of occne environment variables. Values for variables are required. See below for description.
OCCNE Variables
Variable Definitions
occne_cluster_name k8s cluster name
nfs_host IP address OS install nfs host (host running the os_install container)
nfs_path path to mounted OS install media on nfs host. This should always be set to /var/occne/
subnet_ipv4 subnet of IP addresses available for hosts in the OCCNE cluster
subnet_cidr subnet_ipv4 in cidr notation format
netmask subnet_ipv4 netmask
broadcast_address broadcast address on the OCCNE cluster on which pxe server will listen
default_route default router in the OCCNE cluster
next_server IP address of TFTP server used for pxe boot (host running the os_install container)
name_server DNS name server for the OCCNE cluster
ntp_server NTP server for the OCCNE cluster
http_proxy HTTP Proxy server
https_proxy HTTPS Proxy server
occne_private_registry OCCNE private docker registry
occne_private_registry_address OCCNE private docker registry address
occne_private_registry_port OCCNE private docker registry port
metallb_peer_address address of the BGP router peer that metalLB connects to
metallb_default_pool_protocol protocol used to metalLB to announce allocated IP address
metallb_default_pool_addresses range of IP address to be allocated by metalLB from the default pool
pxe_install_lights_out_usr ILO user
pxe_install_lights_out_passwd ILO user password
pxe_config_metrics_persist_size (optional) Logical volume size for Metrics persistent storage, will override default of 500G
pxe_config_es_data_persist_size (optional) Logical volume size for ElasticSearch data persistent storage, will override default of 500G
pxe_config_es_master_persist_size (optional) Logical volume size for ElasticSearch master persistent storage, will override default of 500G
