Table 2-1 Oracle eDelivery Artifact Acquisition
| Artifact | File Type | Description |
| occne-images-1.0.1.tgz | Tar GZ | OCCNE Installers (Docker images). Available in Docker Registry |
| v980756-01.zip | Zip of tar file | Zip file of MySQL Cluster Manager 1.4.7+Cluster. Available in File repository |
| v975367-01.iso | ISO | OL7 ISO. Available in File repository |
| Install Docs | PDFs | This document explains Install procedures. Documents are available in OHC. |
| Templates | Config files (.conf, .ini) | Switch config files, hosts.ini file templates from OHC. It is Local media |
