| Oracle® Communications Network Exposure Function (NEF) Cloud Native Installation and Upgrade Guide Release 1.0 F16986-01 |
![]() Previous |
![]() Next |
Following are pre-requisites user must have before installing Network Exposure Function.
| Software | Version |
| Kubernetes | v1.12.5 |
| HELM | v2.11.0 |
| MySQL | 5.7 or later |
Additional software that needs to be deployed as per the requirement of the services:
| Software | Chart Version | Notes |
| elasticsearch | 1.21.1 | Needed for Logging Area |
| elastic-curator | 1.2.1 | Needed for Logging Area |
| elastic-exporter | 1.1.2 | Needed for Logging Area |
| logs | 2.0.7 | Needed for Logging Area |
| kibana | 1.5.2 | Needed for Logging Area |
| grafana | 2.2.0 | Needed for Logging Area |
| prometheus | 8.8.0 | Needed for Logging Area |
| prometheus-node-exporter | 1.3.0 | Needed for Metrics Area |
| metallb | 0.8.4 | Needed for External IP |
| metrics-server | 2.4.0 | Needed for Metrics Server |
| tracer | 0.8.3 | Needed for Tracing Area |
In case any of the above services are needed and the respective software is not installed in CNE. Please install software before proceeding.Note:
If you are using NRF, install it before proceeding with the NEF installation.Network Access
The Kubernetes cluster hosts must have network access to:
Laptop/Desktop Client Software
Following are the requirements for the laptop/desktop where the deployment commands shall be executed:kubectl commands. The environment should have
privileges to create namespace in the Kubernetes cluster.
helm install command deploys the software in
Browser Support
It is recommend to use Firefox browser to access Kubernetes dashboard. The Configuration Management GUI page is accessed from different browsers.
Server or space requirements
For server and space requirements, refer to Oracle Communications Cloud Native Environment Installation Guide.
