| Oracle® Communications Network Exposure Function (NEF) Cloud Native Installation and Upgrade Guide Release 1.0 F16986-01 |
![]() Previous |
![]() Next |
To update API-Gateway service:
kubectl edit svc
<NEF_NAME>-api-gateway -n <NEF_NAME_SPACE>
Table 3-1 Variables
| Field | Description |
| NEF_NAME | The --name value used in helm install command |
| NEF_NAME_SPACE | The --namespace value used in helm install command |
Following is an sample content that displays in API-Gateway edit window
1 # Please edit the object below. Lines beginning with a '#' will be ignored,
2 # and an empty file will abort the edit. If an error occurs while saving this file will be
3 # reopened with the relevant failures.
4 #
5 apiVersion: v1
6 kind: Service
7 metadata:
8 creationTimestamp: 2019-04-02T08:17:51Z
9 labels:
10 category: common
11 io.kompose.service: <NEF_NAME>-pcf-api-gateway-service
12 name: <NEF_NAME>-pcf-api-gateway-service
13 namespace: <NEF_NAME_SPACE>
14 resourceVersion: "25282719"
15 selfLink: /api/v1/namespaces/<NEF_NAME_SPACE>/services/<NEF_NAME>-pcf-api-gateway-service
16 uid: cec8f019-551f-11e9-acc3-a0369f714f30
17 spec:
18 clusterIP: 10.233.63.101
19 externalTrafficPolicy: Cluster
20 ports:
21 - name: http
22 nodePort: 32314
23 port: 8080
24 protocol: TCP
25 targetPort: 8080
26 selector:
27 io.kompose.service: <NEF_NAME>-pcf-api-gateway-service
28 sessionAffinity: None
29 type: NodePort
30 status:
31 loadBalancer: {}
annotations:
metallb.universe.tf/address-pool:
<ADDRESS_POOL_NAME>
As per user MetalLB setting, select an appropriate pool name to replace the variable,<ADDRESS_POOL_NAME>.
annotation: line must be kept vertical align with line 16, while following line, metallb.universe.tf/address-pool: <ADDRESS_POOL_NAME> must be kept vertical align with line 10. If vertical align restriction failed to follow this rule, the svc yaml file update may fail.
Following is a sample content after replacing line 29.
4 #
5 apiVersion: v1
6 kind: Service
7 metadata:
9 labels:
10 category: common
15 selfLink: /api/v1/namespaces/<NEF_NAME_SPACE>/services<NEF_NAME>-pcf-api-gateway-service
annotations:
17 spec:
20 ports:
21 - name: http
22 nodePort: 32314
23 port: 8080
24 protocol: TCP
25 targetPort: 8080
26 selector:
29 type: LoadBalancer
30 status:
31 loadBalancer: {}
In the new pod, following sample content displays. Note that if the EXTERNAL-IP is available then the load balancer setting for API-Gateway service works.
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE <NEF_NAME>-pcf-api-gateway LoadBalancer 10.xxx.xx.xx 10.xxx.xxx.xx 80:30000/TCP,443:30001/TCP,8001:30373/TCP,8444:31448/TCP 4d
Update cm-service
Follow the same process logic to update svc yaml for <NEF_NAME>-pcf-cm-service.
