| Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide Release 1.0 F16981-02 |
![]() Previous |
![]() Next |
This section includes information about the required pre-requisites before initiating NRF Installation.
Following are the prerequisites to install and configure NRF:
NRF Software
The NRF software includes:
The following software must be installed:
| Software | Version |
| Kubernetes | v1.12.5 |
| HELM | v2.11.0 |
Additional software that needs to be deployed as per the requirement of the services:
| Software | Chart Version | Notes |
| elasticsearch | 1.21.1 | Needed for Logging Area |
| elastic-curator | 1.2.1 | Needed for Logging Area |
| elastic-exporter | 1.1.2 | Needed for Logging Area |
| logs | 2.0.7 | Needed for Logging Area |
| kibana | 1.5.2 | Needed for Logging Area |
| grafana | 2.2.0 | Needed for Metrics Area |
| prometheus | 8.8.0 | Needed for Metrics Area |
| prometheus-node-exporter | 1.3.0 | Needed for Metrics Area |
| metallb | 0.8.4 | Needed for External IP |
| metrics-server | 2.4.0 | Needed for Metric Server |
| tracer | 0.8.3 | Needed for Tracing Area |
In case any of the above services are needed and the respective software is not installed in CNE. Please install software before proceeding.Network access
The Kubernetes cluster hosts must have network access to:
All the kubectl and helm related commands that are used in this document must be executed on a system depending on the infrastructure of the deployment. It may be some client machine (VM, server, local desktop so on).Client machine requirement
kubectl commands. The
environment should have privileges to create namespace in the Kubernetes
cluster.
helm
install command deploys the software in the Kubernetes cluster.
