| Oracle® Communications Network Repository Function (NRF) Cloud Native Installation and Upgrade Guide Release 1.0 F16981-02 |
![]() Previous |
![]() Next |
The following table provides information about the acronyms and the terminology used in the document.
Table 1-1 Acronyms
| Field | Description |
| 5G-AN | 5G Access Network |
| 5GC | 5G Core Network |
| AMF | Access and Mobility Management Function |
| CNE | Cloud Native Environment |
| MMI | Machine Machine Interface |
| MPS | Messages Per Second |
| NF | Network Function |
| Network Function | A functional building block within a network infrastructure, which has well defined external interfaces and well defined functional behavior. In practical terms, a network function is often a network node or physical appliance. |
| Network Slice | A logical network that provides specific network capabilities and network characteristics. |
| Network Slice instance | A set of Network Function instances and the required resources (e.g. compute, storage and networking resources) which form a deployed Network Slice. |
| NF Consumer | A generic way to refer to an NF which consumes services provided by another NF. Ex: An AMF is referred to as a Consumer when it consumes AMPolicy services provided by the PCF. |
| NF Instance | A specific instance of a network function type. |
| NF Producer or NF Provider | A generic way to refer to an NF which provides services that can be consumed by another NF. Ex: A PCF is a provider NF and provides AMPolicy Services |
| NRF | Network Repository Function or Network Function Repository Function |
| Resiliency | The ability of the NFV framework to limit disruption and return to normal or at a minimum acceptable service delivery level in the fame of a fault, failure, or an event that disrupts normal operation. |
| Scaling | Ability to dynamically extend/reduce resources granted to the Virtual Network Function (VNF) as needed. This includes scaling out/in or scaling up/down. |
| Scaling Out/In/ Horizontally | The ability to scale by add/remove resource instances (e.g. VMs). Also called scaling Horizontally. |
| Scaling Up/Down/ Vertically | The ability to scale by changing allocated resources, e.g. increase/decrease memory, CPU capacity or storage size. |
| PCF | Policy Control Function |
| SEPP | Security Edge Protection Proxy |
| SCP | Service Controller Proxy |
| 5G System | 3GPP system consisting of 5G Access Network (AN), 5G Core Network and UE |
