Go to primary content
Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide
Release 1.0
F12352-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
How to use this document
Although this document is primarily to be used as an initial installation guide, its secondary purpose is to be used as a reference for Disaster Recovery procedures.
When executing this document for either purpose, there are a few points which help to ensure that the user understands the author’s intent. These points are as follows:
  1. Before beginning a procedure, completely read the instructional text (it will appear immediately after the Section heading for each procedure) and all associated procedural WARNINGS or NOTES.
  2. Before execution of a STEP within a procedure, completely read the left and right columns including any STEP specific WARNINGS or NOTES.
If a procedural STEP fails to execute successfully, STOP and contact Oracle’s Customer Service for assistance before attempting to continue. My Oracle Support for information on contacting Oracle Customer Support.
Figure 1-1 Example of a Procedure Steps Used in This Document
