| Oracle® Communications Unified Data Repository Cloud Native Installation and Upgrade Guide Release 1.0 F17617-01 |
![]() Previous |
![]() Next |
Following are the pre-requisites you must have before proceeding with the Cloud Native User Data Repository installation.
Oracle Communications User Data Repository Software
The Oracle Communications User Data Repository software consists of:
The following software must be installed.
| Software | Version |
| Kubernetes | v1.12.5 |
| HELM | v2.11.0 |
Additional software that needs to be deployed as per the requirement of the services:
| Software | Version | Notes |
| elasticsearch | 1.21.1 | Needed for Logging Area |
| elastic-curator | 1.2.1 | Needed for Logging Area |
| elastic-exporter | 1.1.2 | Needed for Logging Area |
| logs | 2.0.7 | Needed for Logging Area |
| kibana | 1.5.2 | Needed for Logging Area |
| grafana | 2.2.0 | Needed for Metrics Area |
| prometheus | 8.8.0 | Needed for Metrics Area |
| prometheus-node-exporter | 1.3.0 | Needed for Metrics Area |
| metallb | 0.8.4 | Needed for External IP |
| metrics-server | 2.4.0 | Needed for Metric Server |
| tracer | 0.8.3 | Needed for Tracing Area |
In case any of the above services are needed and the respective software is not installed in CNE, install software before proceeding.Create Database User/Group
The UDR uses a NDB MySQL database to store the subscriber information.
The UDR deployment using MySQL NDB cluster requires the database administrator to create user in MYSQL DB and to provide the user with necessary permissions to access the tables in the NDB cluster.
CREATE USER '<username>'@'%' IDENTIFIED BY '<password>'; DROP DATABASE if exists udrdb; CREATE DATABASE udrdb CHARACTER SET utf8; GRANT SELECT, INSERT, CREATE, ALTER, DROP, LOCK TABLES, CREATE TEMPORARY TABLES, DELETE, UPDATE,EXECUTE ON udrdb.* TO '<user>'@'%'; USE udrdb;
Network access
The Kubernetes cluster hosts must have network access to:
Laptop/Desktop Client software
Following are the requirements for the laptop/desktop where the deployment commands shall be executed:
kubectl commands. The
environment should have privileges to create namespace in the Kubernetes
cluster.
'helm
install' command deploys the software in the Kubernetes cluster.
All the kubectl and helm related commands that are used in this document must be executed on a system depending on the infrastructure of the deployment. It could be user machine such as VM, server, local desktop and so on.
