| Oracle® Communications Unified Data Repository Cloud Native Installation and Upgrade Guide Release 1.0 F17617-01 |
![]() Previous |
![]() Next |
The User Data Repository deployment could be customized by overriding the default values of various configurable parameters.
In Deploying Cloud Native User Data Repository, the MySQL host is customized.
A ocudr_values.yaml file could be prepared by hand to customize the parameters.
Following is an example of User Data Repository customization file.
# Copyright 2018 (C), Oracle and/or its affiliates. All rights reserved.
ocudr:
image:
repository: reg-1:5000/ocudr/nudr_datarepository_service
tag: 1.0.0
pullPolicy: Always
service:
http2enabled: "true"
type: ClusterIP #Note: Suggested to be set as ClusterIP (default value) always
port:
http: 80
https: 443
management: 9000
deployment:
replicaCount: 2
mysql:
primaryhost: "ocudr-mysql"
primaryport: "3306"
secondaryhost: "ocudr-mysql"
secondaryport: "3306"
dbname: "udrdb"
dsusername: "udruser"
dspassword: "udrDbPasswd"
hikari:
poolsize: "25"
logging:
level:
root: "WARN"
nrfClient:
host:
baseurl: "http://ocnrf-endpoint.mynrf.svc.cluster.local/nnrf-nfm/v1/nf-instances"
proxy:
ssl: "false"
logging:
level:
root: "WARN"
image:
repository: reg-1:5000/ocudr/nrf_client_service
tag: 1.0.0
pullPolicy: Always
capacityMultiplier: "500"
supirange: "[{\"start\": \"10000000000\", \"end\": \"20000000000\"}]"
priority: "10"
livenessProbeUrl: "http://nudr-drservice.myudr.svc.cluster.local:9000/actuator/health,http://ocudr-ambassador-admin.myudr.svc.cluster.local:8877/ambassador/v0/check_ready"
fqdn: "ocudr-ambassador.myudr.svc.cluster.local"
ambassador:
jaeger:
service:
port: 9411
resources:
requests:
cpu: 3
target:
averageCpuUtil: 80
minReplicas: 1
maxReplicas: 4
ambassador:
ambassador:
service:
type: LoadBalancer
annotations:
metallb.universe.tf/address-pool: signaling
adminService:
type: LoadBalancer
annotations:
image:
repository: quay.io/datawire/ambassador
tag: 0.40.2
pullPolicy: IfNotPresent
resources:
requests:
cpu: 3
