Creating a Bootable USB Drive from on Linux
Before starting this process, ensure that the capacity of your USB drive is at least 4 GB.
To
create a bootable USB drive from on Linux:
- Download the D2000 or D6000 image from MOS.
Copy the image on
the USB drive.
Doing this, destroys all existing data on the USB drive.
Insert the USB
drive into the computer and run the
dmesg|tailcommand.[4317966.832947] usb 4-1: new SuperSpeed USB device number 39 using xhci_hcd [4317966.845892] usb 4-1: New USB device found, idVendor=0951, idProduct=1666 [4317966.845893] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [4317966.845894] usb 4-1: Product: DataTraveler 3.0 [4317966.845895] usb 4-1: Manufacturer: Kingston [4317966.845896] usb 4-1: SerialNumber: E0D55EA57419E3C139680956 [4317966.848319] usb-storage 4-1:1.0: USB Mass Storage device detected [4317966.848421] scsi host6: usb-storage 4-1:1.0 [4317967.863955] scsi 6:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6 [4317967.864524] sd 6:0:0:0: Attached scsi generic sg4 type 0 [4317967.864606] sd 6:0:0:0: [sdd] 60604416 512-byte logical blocks: (31.0 GB/28.9 GiB) [4317967.864790] sd 6:0:0:0: [sdd] Write Protect is off [4317967.864792] sd 6:0:0:0: [sdd] Mode Sense: 45 00 00 00 [4317967.864972] sd 6:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
In this case, the
device name is
"sdd", and will be referenced by Linux as“/dev/sdd”. -
If Linux has been
configured to auto-mount USB devices, unmount the partitions on the drive. Run
the
“df”command to detect the status of the partitions of the drive:In this example, the second partition of /dev/sdd is mounted and must be unmounted. In your case there may be no mounts on the USB or more.
df Filesystem 1K-blocks Used Available Use% Mounted on devtmpfs 16416036 0 16416036 0% /dev /dev/mapper/ol_lobi7u6-root 52403200 37842328 14560872 73% / /dev/sda1 1038336 427060 611276 42% /boot /dev/mapper/ol_lobi7u6-home 164415040 112140980 52274060 69% /home /dev/sdd2 2755604 2389404 222896 92% /run/media/oracle/USBBoot
To unmount the
partition on the drive, run the command:
umount /run/media/oracle/USBBoot. -
Run the
dfcommand again to make sure that there are no mounts matching your USB device name (/dev/sddin the example.) - Insert the USB drive. At this point, the USB drive is ready to receive the image.
gunzip the
downloaded USB raw image file.
gunzip d6000v1_OS_7_0_1_0_0_GA_02282020_OS_52_GA_05022019_R8_2_1_0_0_GA_01282020.raw.gz
Burn the image,
copy the USB raw image file to the USB device.
In the example, the USB device is identified as
dev/sdd. This command requires root access and is prefixed with “sudo”.sudo cp d6000v1_OS_7_0_1_0_0_GA_02282020_OS_52_GA_05022019_R8_2_1_0_0_GA_01282020.raw /dev/sdd
The USB
burn process on a USB3 device can take 15 minutes. It may take a longer time if
the device or port is USB2. After the process is complete, you can remove the
USB. It is ready for use.
