Network Deployment Options
Before getting started, it is important to determine how the Oracle Talari D2000 will be deployed.
When considering deployment options, please note that the bypass pairs will default to Fail-To-Block until configured otherwise.Example instructions for some of the most common deployment scenarios are provided below:
Router (Gateway, Fail to Block)
The Oracle Talari D2000 is deployed as the WAN gateway for the site, and bypass pair is configured as Fail-To-Block. Use this option if you plan to use the Talari Appliance as the edge device for the site.
Layer 2 Fail-To-Wire (Overlay)
The Oracle Talari D2000 is deployed on the LAN side of the gateway, and bypass pair is configured as Fail-To-Wire. Use this option if you prefer to retain existing edge devices or plan to install an alternative edge device on the WAN side of the Talari Appliance.
MPLS & Internet Hybrid
The Oracle Talari D2000 is deployed as an overlay for MPLS while performing routing/firewall capabilities for internet links. Use this option if recommended by your Sales Architect, or if you have an MPLS/Internet hybrid network and will not be using the CE Router Replacement functionality of Oracle SD-WAN Edge.
Other Options
There are other deployment options, and our Talari Implementation team members will assist you with planning and deploying your new appliance.
