Hardware and Software Requirements
Oracle Talari D2000 appliances have the following hardware and software requirements.
Hardware
D2000 appliances require a standard 19 inch (480mm) 4-post rack for mounting.
Software
The Talari Web Console is supported in latest versions of
the following web browsers:
- Microsoft IE9 - IE11
- Mozilla Firefox
- Google Chrome
Supported browsers must have cookies enabled.
Supported browsers must have JavaScript installed and enabled.
Display
A minimum screen resolution of 1024 x 960 or greater is recommended.
