LAN/WAN Connections
When connecting each Ethernet cable (LAN, WAN) to the appropriate connector on the D2000.
- Position the cables carefully, so that they do not put strain on the connectors.
- Organize cables in bundles such that cables do not intertwine.
- Inspect the cables to make sure that the routing and bend radii are satisfactory. Reposition cables, if necessary.
- Install cable ties in accordance with site requirements.
