Installation Option: Manual Install
For use with D6000 as a Router (Gateway, Fail to Block), Layer 2 Fail to Wire (Overlay), MPLS and Internet Hybrid
Manual Install Site Deployment Criteria
Manual (Legacy) Install requires physical access to the appliance. The end user will require a PC which can be connected to the console port of the Talari Appliance. The console port connects the user to the Oracle ILOM command line interface. Cable management, LAN, and WAN ports according to the Talari configuration for site.
Pre-Deployment Requirements
The network administrator must have an active configuration which includes a client package for this site running on the NCN. An appropriate IP address, subnet mask, and gateway for the management interface should be provided for the on-site user to configure.
- From the Web Console of the NCN, navigate to Manage Network, and then Change Management.
- Download the active package for the new client site.
- Send the zipped client package to the on-site user who will be deploying the appliance.
Deploying the Talari Appliance
- Connect the power cords to the D6000. Connect the other ends to an appropriately grounded power source. The D6000 will power on automatically.
- Connect the PC directly to the console port of the D6000 and console into the appliance using a bit rate of 115200/8-N-1.
- Log in to Oracle ILOM as an Administrator. To enable first time login and access to Oracle ILOM, a default Administrator account and its password are provided with the system. To build a secure environment, change the default password (Welcome1) for the default Administrator account (root) after your initial login. You may change the password using the command "set /SP/users/root/ password".*
- Enter the command "start /HOST/console", confirm, and hit enter again to access the Talari console.
- Log in to the appliance via the command line. To enable first time login and access to the Talari appliance, a default administrator account and its password are provided with the system. To build a secure environment, change the default password (talari) for the default Administrator account (talariuser) after your initial login.
- Enter the command "tcon" and wait for the prompt to return.
- Enter the command "management_ip".
- Stage the IP Address, Subnet Mask, and Gateway IP Address for the Talari as provided by the network administrator using the command "set interface <ip address> <subnet mask> <gateway>". Review the staged settings, then enter the "apply" command to activate.
- Disconnect from the console. If the network administrator will be configuring the appliance, no further action is required.
- To apply the configuration package, navigate to the Talari management IP in a web browser and log in to the Talari web console using the credentials given above. Select Configuration > Local Change Management from the left-hand menu.
- Click Browse and select the .zip package provided by your network administrator, then click Upload.
- When the upload is complete, click Next to proceed to activation.
- Click Activate Staged to complete the process.
- Once the activation process is complete, navigate to Manage Appliance > Enable/Disable Services and enable the Talari service.
