Hardware Specifications
The D6000 has the following hardware specifications.
| Power |
Redundant 1200 watt power supply 100-240V 50-60 Hz |
| Estimated BTU Per Hour |
Active idle: 618 BTU/hr 50% Workload: 1140 BTU/hr 90% Workload: 1559 BTU/hr |
| Physical Dimensions |
Height 1.68” (42.6mm) Width 18.9” (482mm) Depth 29.02” (737mm) Gross Weight 40 lbs (18.1kg) |
| Mounting Options |
Rack mount, rail kit (included) |
| System LEDs | |
| Link LEDs |
Link activity Link speed |
| Operating Temperature |
41°F to 95°F (5° to 35°C) |
| Storage Temperature | -40°F to 154°F (-40°C to 68°C) |
| Humidity Range | 10% to 90% (non-condensing) operating environment |
| Network Data Interfaces |
8 Gigabit Ethernet Fail-To-Wire Ports 2 1/10-Gigabit Ethernet SFP+ Ports |
| Other interfaces |
1 Gigabit Ethernet Management Port 1 USB 3.0 port 1 RJ-45 Console Port |
