Modifying Risk Thresholds
If you are going to change the type or level of a threshold that is currently assigned to a scoring matrix, you must first remove the threshold from the risk scoring matrix and assign a new threshold.
To delete a threshold from a risk scoring matrix:
  1. Click Administration.
  2. On the Administration navigation bar, click Enterprise Data.
  3. On the Enterprise Data page, expand Risks and click Risk Scoring Matrices.
  4. On the Risk Scoring Matrices page:
    1. Locate the risk scoring matrix that includes the threshold you are modifying.
    2. Double-click in the appropriate threshold field.
  5. In the Select Threshold dialog box, choose a different threshold and click Select.
  6. On the Risk Scoring Matrices page, click Save.
To modify a risk threshold:
  3. On the Enterprise Data page, expand Risks and click Risk Thresholds.
  4. On the Risk Thresholds page:
    1. Locate the threshold you are modifying.
    2. Double-click in the field you are modifying and update the value.
      Note: If you are modifying the number of levels assigned to a threshold, all data for existing levels are overwritten and replaced with the default values for that level.
    3. Click Save.
Related Topics
About Risk Thresholds
Working with Risk Thresholds
Creating Risk Thresholds
Risk Thresholds Page
Risk Scoring Matrices Page
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
