Applying Filters
Apply filters to a project to specify the data you want to display. You can add user-created filters or select from the list of standard filters.
To apply filters:
  1. Click Projects.
  2. On the Projects navigation bar, click Activities or EPS.
    1. On the Activities or EPS page:
      • Click the Views list and select a view to which you will add the filters.
      • Click Customize View.
    2. In the Customize View dialog box, click the Filtering tab.
    3. On the Filtering tab:
      • Select to match all applied or any applied.
      • In the filter list, select the option for each filter you want to apply.
      • Click Save and Apply.
Tips
Related Topics
Configuring Activity View Filters
Creating Filters
Configuring Filters
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
