You need to assign a risk scoring matrix to a project before it can be used to prioritize risks. Once you assign a scoring matrix to a project, it is available for use from the risk register on the Risks page in the Projects section.
You can assign a risk scoring matrix to a project from multiple locations in the application. Use this method when you are defining a risk scoring matrix and need to apply the matrix to one or more projects.
To assign a risk scoring matrix to a project from the Enterprise Data pane:
- Click Administration.
- On the Administration navigation bar, click Enterprise Data.
- On the Enterprise Data page, expand Risks and click Risk Scoring Matrices.
- On the Risk Scoring Matrices page, select the matrix to assign to the project and click the Projects detail window.
- In the Projects detail window, click Assign....
- In the Select Project dialog box:
- Select a project and click Select.
Note: If the project you selected is assigned to another risk scoring matrix, the threshold values you previously set for the project are removed. You will need to select values using the newly assigned risk scoring matrix.
- On the Risk Scoring Matrices page, click Save.
