Import/Export features allow you to bring data into P6 as well as export data to other tools when needed.
Available Import Options:
- Import projects from other P6 EPPM users or Microsoft Project
- Import multiple projects in a single XML file
- Import Activities
- Import Resources
- Import Locations
- Import Appointments as personal non-work exception time from Microsoft Outlook and other applications that support the iCalendar format
- Move activity codes and calendars to projects
- Remove codes, UDFs, and calendars from projects
- Rename codes, UDFs, and calendars
- Specify resource hierarchical position for importing into the resource breakdown structure
- Map resources to generic resource names
- Save import options in a template
- Import views
- Import enterprise data
Available Export Options:
- Export Projects
- Export multiple projects in a single XML file
- Export Activities
- Export Resources
- Export Resource Allocation and Cost
- Export Risks
- Export views
- Export enterprise data
Note: For best practices on exporting data from P6 EPPM to be imported into Oracle Primavera Cloud, see: Primavera Cloud P6 EPPM XML Import Guide.
