Sending Email Notifications about Resource Assignments
An automatic notification feature can be configured to send Email to the affected resources when you add, change, or remove a resource assignment.
To configure P6 to automatically send Email about resource assignments:
  1. Click the User menu and select My Preferences.
  2. On the My Preferences page, click the Global tab.
  3. On the Global tab, expand the General section.
  4. In the General section:
    1. Select the Send Email to resources upon adding or removing assignments option.
    2. The system automatically selects the Prompt before sending Email option. Clear the option if you do not want prompts.
  5. On the Global tab, click Save and Close.
Tips
Related Topics
Customizing My Preferences Global Preferences
Customizing Global Currency Preferences
Customizing Global Date Format Preferences
Customizing Email Notification Preferences
Customizing Global Performance Threshold Preferences
Customizing Project Score Preferences
Customizing Global Resources Preferences
Customizing Global Row Number Preferences
Customizing Global Time Units Format Preferences
My Preferences Page
Global Tab of the My Preferences Page
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
