You can export the resource dictionary in P6 Professional project to XER format, then import the XER file to Oracle Primavera Contractor 5.0 or 6.1 or later. You cannot import an XER file to an earlier version of Oracle Primavera Contractor than 5.0.
- Choose File, Export.
- Choose Primavera Contractor - (XER).
- Select the appropriate version from the pull-down menu. Click Next.
- Choose Resource Only. Click Next.
- Type or select the name of the export file and the location where the file will be saved.
- Click Finish.
- Click Close.
Note
- While both P6 Professional and Oracle Primavera Contractor 5.0 or 6.1 or later can import and export XER files, the formats of the XER files are different. Therefore, when exporting resources for use with Oracle Primavera Contractor 5.0 or 6.1 or later, you must select the Primavera Contractor - (XER) option instead of the Primavera PM - (XER) option.
