All reports created with the wizard automatically include a row that contains the variable text cell Notes, which corresponds to the Notes field of the Run Report dialog box. When you run a wizard report, the comments you enter in the Notes field are printed in the report and saved. These comments are included each time you run the same report or another report, unless you clear or edit the Notes field.
- With the Reports window active, select the report and click
on the Reports toolbar.
You can also right-click on the report and choose Report, Run. - In the Notes field, type your comments.
Tip
- For the comments you enter in the Notes field to be included in the printed report, the report must include the variable text cell Notes. If you edited a wizard report and removed the variable Notes field, use the following steps to restore it.
- With the Reports window active, click
You can also right-click on the report and choose Modify. - To add a row for comments, click in the area of the Report Canvas where you want the comments to appear, then click
. You can type a new height or click the color button to specify a new row color.
- To add a text cell to the row, click
. In the Cell Type field, select Variable. In the Cell Variable field, select Notes. In the Font Style field, select one of the available default body fonts.
