Use Print Setup to select a printer other than the current default to print layouts and reports.
- Choose File, Print Setup.
- In the Printer section, select a printer.
- Click Properties to adjust the features and settings for the selected printer.
- In the Paper section, choose the paper settings from a list of available page sizes and paper sources that match the capabilities of the selected printer.
- Choose Portrait or Landscape for the paper orientation.
- Click Network to direct your output to any network print queue.
- Click OK.
Note
- Only the paper size and orientation is saved when you save a layout and log out of P6 Professional.
