Specify line cell width and position in a row
- In the Edit Report window, click the line cell, then click
- Click the Line tab. In the Line alignment field, select the position you want the cell to occupy in the row.
To use your mouse to drag the cell to the appropriate position in the row, select None.
To position the cell relative to the left margin, select Left, then type the cell's left indent in the Left field.
To position the cell flush against the right margin, select Right.
To extend the cell, or line, across the entire row, select Center.
- In the Width field, type the cell's numeric width, the distance you want the cell to occupy between the report's left and right margins.
If the cell's alignment is Center, you cannot enter the cell's width.
Tip
- You can also change a cell's width directly in the Report Editor window. Select the line cell, then position the mouse pointer over the cell's left or right edge. When the pointer changes to a double-headed arrow, drag the cell's edge to a new position.
