Use the Admin Categories dialog box to define standard categories and values that you can apply to all projects.
The Admin Categories dialog box contains the following tabs:
- Baseline Types tab - Admin Categories dialog box
- Expense Categories tab - Admin Categories dialog box
- WBS Category tab - Admin Categories dialog box
- Document Categories tab - Admin Categories dialog box
- Document Status tab - Admin Categories dialog box
- Notebook tab - Admin Categories dialog box
- Risk Categories tab - Admin Categories dialog box
- Units of Measure tab - Admin Categories dialog box
Note
- The Shift Up and Shift Down buttons are available only with the manual display order. An outline symbol in the category column title indicates a manual display order.
