Use the Assign Access to OBS dialog box to enable the selected user to access project data for the EPS and WBS elements related to a specific OBS member.
Display Options bar: Lists options for changing the organizational breakdown structure (OBS) display.
OBS Name: Lists the organizational breakdown structure (OBS). To sort the display, click the OBS Name column label.
Assign: Assigns the selected OBS element to the Project Access list.
Remove: Removes the selected OBS element from the Project Access list.
