- Choose Project, Issues, then select the issue.
- Display Issue Details, then click the Details tab.
- In the Applies to Resource field, click , select the resource to which you want to assign the issue, then click the Select button.
Note
- If the threshold monitor generated the selected issue, you cannot assign the issue to a resource or change the issue's resource assignment.
