- Choose Enterprise, Roles, then select the role to which you want to assign a code and value.
- Click the Codes tab.
- Click Assign.
- Select the role code value you want to assign.
You can only assign one value per code. - Click Assign, then click Close.
Tips
- To change a code value assignment, double-click the code value you want to change and select a new code value.
- To remove a role code, select the code and value you want to remove in the Codes tab, then click Remove.
