Use the Batch Reports dialog box to define report batches for running global and project reports.
Global: Choose to add, edit, or delete report batches that are not project-specific.
Project: Choose to add, edit, or delete report batches for the open project only.
Display Options bar: Click to search for a specific report batch.
Batch Report: Lists names of report batches for the current batch type. To change a report batch name, double-click it. To sort the list, click the Batch Report column label.
Report Name: Lists names of reports included in the selected batch report.
Assign: Click to add reports to the selected report batch.
Remove: Click to remove reports from the selected report batch.
Arrows: Change the selected report’s position in the report batch.
Add: Adds a report batch.
Delete: Deletes the selected report batch.
