Use the Calendars in Use dialog box to specify how you want to delete a calendar.
Select Replacement Calendar: Choose to reassign the selected calendar's assignments to a calendar that you specify.
Link to Default Global Calendar: Choose to reassign the selected calendar's assignments to the default global calendar.
