Check out a project to XML
- Open the projects you want to check out.
- Choose File, Check Out...
- Select the projects you want to check out.
To check out a project, it must be open. If the project you want to check out is not on the list, click Cancel, open the project, and restart the wizard.
- Select Check out to XML.
- Click Finish.
An XML file is created that exports complete project information to other P6 Professional or P6 EPPM applications.
Note
- To move between different wizard windows, click Prev or Next.
