Create EPS-level activity code values
- Choose Enterprise, Activity Codes.
- Choose EPS.
- Select the activity code for which you want to create a value, then click Add.
- Type the value's name.
- Type the value's description.
Tips
- You can arrange activity code values hierarchically using the arrow buttons on the Activity Codes dialog box.
- You can define the maximum number of levels in an activity code hierarchy on the Data Limits tab of the Admin Preferences dialog box when P6 Professional is connected to a P6 Professional database and from the P6, Application Settings when connected to a P6 EPPM database.
- You can also create a new activity code value when assigning an activity code value to an activity.
