Use the Curtain Attachment dialog box to highlight a specific time period in a Gantt Chart. This dialog box contains the following elements:
Display curtain attachment: Mark or clear the checkbox to display or hide the curtain attachment.
Start Date: Click the Browse button to select a start date for the curtain display.
Finish Date: Click the Browse button to select a finish date for the curtain display.
Color: Click to select a color for the curtain.
Fill Pattern: The fill pattern of the selected curtain's start and finish dates.
OK: Click to accept changes.
Cancel: Click to close the dialog box without saving changes.
Delete: The delete button is available when you are using the dialog box to edit an existing curtain. Click to remove the curtain from the Gantt Chart.
Tip
- Curtain attachments are associated with the open layout, not the open project(s). Therefore, you will need to save the layout to make curtain attachment additions and deletions permanent.
