- Choose Project, WBS.
- Select a WBS element associated with the work product or document.
- Display WBS Details, then click the WPs & Docs tab.
To display the WPs & Docs tab, right-click in the Details area and choose Customize WBS Details. In the Available Tabs section, select WPs & Docs, click , then click OK.
- Select the work product or document, then click Details.
To view the work product or document, click Launch next to the appropriate Location field.
Note
- Only P6 Professional users can open private location documents. Public location documents can be viewed by all project participants.
Display work breakdown structure details
