- Choose Enterprise, OBS.
- Click the OBS Name column label to display the OBS hierarchy.
The outline symbol in the OBS Name column label indicates a hierarchy display.
- Select the OBS element you want to edit.
- To change the element's information, click the General tab and enter new information.
- To change the element's position in the OBS, click the appropriate arrow buttons.
