Currency ID: The identifier for the selected currency. You can type a new ID.
Currency name: The name of the selected currency. You can type a new name.
Currency symbol: The symbol used to identify the selected currency. You can type a new symbol.
Exchange rate: The current exchange rate for the selected currency. You can type a new value.
Note
- You cannot change the exchange rate of the base currency.
