- Choose Project, Activities, then choose View, Group and Sort By.
To view the WBS Path in the WBS view, choose Project, WBS. Then choose View, Group and Sort by, WBS Path. - In the Group By section, click the cell, then select WBS Path.
- Click Sort, then select a sort order for the WBS path. Click OK.
- To change the grouping band's attributes, such as the color and font, double-click the appropriate Font & Color field.
