Use the Modify Template dialog box to select the options used when exporting data for use with Microsoft Excel or other third-party applications.
Template Name: The name of the export template. Enter a name that describes the template or the activities to which the template will typically apply.
Subject Area: The areas of interest selected to export. Select the subject area to define its export specification.
The following tabs are available:
- Columns tab - Modify Template dialog box for use with Microsoft Excel files
- Filter tab - Modify Template dialog box for use with Microsoft Excel files
- Sort tab - Modify Template dialog box for use with Microsoft Excel files
Default: Applies the default column setting to the template.
