You can set user preferences to specify which projects to include and which dates and interval you want to use to calculate values for a resource profile.
- To display the Resource Analysis tab, click it.
- If you chose the Show Remaining Bars As, Total Remaining option, to specify which closed projects you want to include, if any, select an option in the All Projects section.
- To specify which dates you want to use to calculate remaining values, in the Time-Distributed Data section, select a date option.
- To specify the interval you want to use for live spread data calculations, in the Interval for Time Distributed Resource Calculations field, select an option.
Note
- For the most efficient forecast of summary data, We recommend that you select the same interval as specified for the timescale in the profile/spreadsheet.
