When you display a toolbar, it is placed in its default location, which can be above or beside the workspace. You can drag any toolbar to a different location anywhere in the toolbar area or the workspace.
- For toolbars displayed horizontally, hover over on the left end of the toolbar until the cursor changes to a crosshair, then drag the toolbar to the appropriate location.
- For toolbars displayed vertically, hover over at the top of the toolbar until the cursor changes to a crosshair, then drag the toolbar to the appropriate location.
- For floating toolbars (toolbars you've moved from the toolbar area to the workspace area), click the title bar, then drag it.
Tips
- Floating toolbars always appear in the workspace, regardless of the active window.
- To reshape a floating toolbar, hover over any edge of the toolbar until the cursor changes to an arrow, then drag the cursor.
- You can move the Menu bar.
- You can revert to the default settings for an individual toolbar, or for all toolbars.
