A Project Bar Chart consists of bars representing either cost, unit, earned value, earned value labor unit, or total activities data for EPS nodes, projects, or WBS elements.
You can include up to three bars for any data category. For example, choose to display earned value data and include bars to represent Planned Value Cost, Earned Value Cost, and Actual Cost. You can specify the color of each bar and indicate whether you want the bars to be stacked or included on the same line as the preceding bar.
The EPS node, project, or WBS element that corresponds to each bar is listed in columns to the left of the Bar Chart; the order in which these elements are listed depends on the current group and sort options. You can choose to hide the left columns. You can group the Bar Chart by project, EPS/WBS, OBS, WBS category, or by specific WBS data. You can also show grand totals and/or summary data only, and sort by any available WBS data type.
