Use the Project Details dialog box to view general information about the selected project. To display the Project Details dialog box from the Tracking window, select a project, right-click, then click Project Details.
The Project Details dialog box contains the following tabs:
- General tab - Project Details dialog box (from Tracking window)
- Status tab - Project Details dialog box (from Tracking window)
- Proj Codes tab - Project Details dialog box (from Tracking window)
- Summary tab - Project Details dialog box (from Tracking window)
