You can promote, or change, an EPS-level activity code and its values to a global activity code with global values.
- Choose Enterprise, Activity Codes.
- Choose EPS, then click Modify.
- Select the code you want to promote, then click Make Global.
- Click Yes, then click Close.
Tip
- If you promote an EPS-level activity code and its values, your change applies to all activity assignments.
