Before you publish a project as a Web site for the first time, you might choose to create a new folder on your computer or network or verify that the existing folder you want to use is empty.
- Open the project you want to publish.
- Choose Tools, Publish, Project Web Site.
- Click the Reports tab.
- Mark the Include in Project Web Site checkbox to include reports in the project Web site.
- Click the Assign button.
- Select the reports you want to include in the Web site, then click the Select button.
- Click Publish.
If the folder you selected contains older Web site files or other files, a message warns you that those files will be deleted. Choose Yes to continue or No to cancel.
The reports are added to the project Web site's HTML folder.
